Error transmission temperature high
65,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
RAKIBS
I need suggestion for Honda Vezel 2014 RU3 (hybrid). I got error transmission temperature high. Two months before transmission fluid changed. But why error came?
In Bangladesh weather too much hot. What is your suggestion for this? Maximum time people face dual clutch problem and change it in our country. How can I keep good condition?
Oct 5, 2019 at 2:58 PM
STEVE W.
  • 15,423 POSTS
Welcome to 2CarPros. That vehicle has at least one recall for updated software for that transmission related to it showing errors. I would probably start by making sure that is updated before any other changes. After that you might consider adding a transmission cooler if they left any room to add one. I try to add larger ones to any vehicle because heat is a big reason for transmission failure and most modern vehicles seem to be engineered to just barely make it out of the warranty before parts fail.
Oct 5, 2019 at 4:25 PM
RAKIBS
Thanks for your advice.
I really don't know how will I get it or which one will fit for this?
Can you provide me any idea how will I get transmission cooler or where I can get it?
can you provide me any link or image or video where I can get some idea?
I am not mechanic so I don't know how to fix it.
Transmission cooler will support Honda vezel ?
Oct 5, 2019 at 11:07 PM
STEVE W.
  • 15,423 POSTS
Most of the add-on coolers look like a small radiator that you install inline with the factory transmission coolers. I cannot find any good information on the cooling or lack of on the Vezel as Honda doesn't sell that particular version in the US and our information sources don't cover those vehicles very well. The Fit Hybrid used the same drive line but it was also not sold here. Being a dual clutch transmission it may not have a cooler at all. What you could do is call a dealer local to you and ask if it has one and if it is possible to add a larger one.
Oct 6, 2019 at 2:38 AM
RAKIBS
Okay, can you show me any links what could be cooler system like this?
Oct 6, 2019 at 12:02 PM
STEVE W.
  • 15,423 POSTS
These are the styles of coolers I'm used to seeing and using. They are all designed to go into the cooling lines that automatic transmissions use, I have seen then on cars with dual clutch designs but those had factory coolers because they were high performance vehicles. Honda doesn't show if they have a cooler or an internal pump that could have one added. That is why I would investigate it with them first, if it already has a cooler then adding on should be simple. If not then it becomes a lot more work.
Oct 7, 2019 at 8:08 AM
