2005 Honda Stream
VIPER_7
Engine Performance problem
2005 Honda Stream 4 cyl Two Wheel Drive Automatic
After switching off the engine. I couldn't restart the vehicle. There was no cranking sound. Battery is available. Nevertheless, tried to jump start but couldn't start. Each time start vehcle has no contact point to start. Please advise stranded in relative house and cannot go back home to family. Thank you.
Nov 6, 2010 at 7:15 AM
KHLOW2008
  • 41,812 POSTS
Hi Viper_7,
Check the starter cut relay. Ensure it is clicking when ignition is turned to START.
Disconnect the starter solenoid wire and apply battery voltage to it to test f the starter cranks. If starter cranks, you can start vehicle with ignition switch ON. Ensure gear shift is in Park.
Nov 6, 2010 at 8:32 AM
