2002 Honda Stream Rattling sound
HENHARJAM2000
  • 5 POSTS
Noises problem
2002 Honda Stream 4 cyl Front Wheel Drive 69000. miles
Hi every one,
when i am driving at 30 - 40 kilometer i herd a rattling sound in the engine area and if you suddenly press down or ease up on the gas at that speed the sound go away can u help me diagnose it please, am Henry, machinist by profession working as a mechanical maintenance at a power plant thanks
Feb 16, 2010 at 3:11 AM
HENHARJAM2000
  • 5 POSTS
Hi every one,
I found the problem that cause the rattling sound. My O2 sensor was bad that is the one before the caterlist and i brought a bash brand the type you must cut and splice for it to fit my car, any way it did not work, the Eng. check light came back and was running rich real rich, start to burn 190 k/m per full tank, so i put in back my old sensor until get the correct one its now three day now and i don't here the noise any more, that mean it was the incorrect sensor that cause the noise in the fuel injectors.
Feb 23, 2010 at 8:14 AM
