Honda starts and when you drive it, it cut you can when check everything when it starts and do the same. Honda 1996 150i 15D3B Engine
Feb 27, 2014 at 6:27 PM
HMAC300
✓Experienced Mechanic
scan for codes and check fuelpressure with agauge in U.s. autoparts rent hem
Feb 28, 2014 at 1:36 AM
PHILLIP1960
MEMBER
It do not have a computer box -, it only have electronic ignition. If I drive the car it goes fin and then the rev counter cut out and then after the engine. If you wait 2 min you can start it and go again, and then it do the same
Feb 28, 2014 at 2:17 AM
HMAC300
we do not have that model in the U.S. but it still should have a computrebox. If not have the electronic ignition checked as a module or pickup coil may be bad. also check your fuses underhood as well as your main relay
