2007 Honda S2000 engine will not start
36,000 MILES • 4 CYL • 2WD • MANUAL
SAMHALL1
i have checked all fuses. the motor attempts to turn when you press the start button but will not turn. i have checked the battery and it is ok.
Sep 19, 2010 at 4:06 AM
KHLOW2008
  • 41,812 POSTS
You should have replied to the previous post instead of posting a new question.
Get the starter motor tested if it seems weak to crank. Was the battery tested for voltage and high rate discharge?
Does jump starting works?
Sep 19, 2010 at 5:21 AM
