2001 Honda S2000 Can't shift into gear 1-6?
TIBURON25
Transmission problem
2001 Honda S2000 4 cyl Two Wheel Drive Manual
Can't shift into gears 1-6. I checked the clutch master cylinder and the fluid is low.
Feb 1, 2010 at 6:43 PM
KHLOW2008
  • 41,812 POSTS
Hi Tiburon25,
If the clutch pedal is low, you would not be able to shift into gears.
There is a leak somewhere causing the clutch hydraulics to fail.
Feb 2, 2010 at 5:13 AM
