Honda Ridgeline Airbag Repair
VICLINER
Purchased a Used Ridgeline recently from a wholesaler. Discovered after purchase, that it was in a collision with airbag deployment. Not sure the extent, but Honda says the repair was done well. Truck seems to run perfectly with no frame damage.
Want to reassure myself that all systems such as VSA, ABS, Airbags are all working correctly after the repair was complete. All the warning lights go on and off after ignition is turned on, as they should.
Question:
Is this enough to say that all systems are OK or is there a diagnostics test I can have done that will ensure it's working as it should?
Nov 12, 2006 at 8:32 AM
BRUCE HUNT
  • 3,754 POSTS
I would say that the computer is satisfied that the items were installed correctly. The lamps lighting and the check engine light working but quiet after start up would be enough for me. The car computer is thorough. If still in doubt I suggest either a front end collision to test or you can take it to the dealer. I would avoid the front ender though!
Nov 12, 2006 at 11:27 AM
VICLINER
Hi Bruce
Thanks for getting back to me. I think I'll avoid the front end collision. Wish there was some definitive answer, but the lamps going off and on when starting up will probably have to be enough for me as well.
Nov 14, 2006 at 9:56 AM
Suggested Repair
Treat the normal startup lamp self-test, with warning lights going out and no check-engine light afterward, as confirmation that the computer sees the repaired systems as installed correctly. If more reassurance is needed, have a Honda dealer scan the airbag/SRS, ABS, and VSA systems rather than relying on a road test.
Conversation Summary
The owner of a used Honda Ridgeline learned after purchase that it had been in a collision with airbag deployment. Honda reportedly said the repair was done well, the truck runs normally with no frame damage, and the warning lights cycle on and off at startup as expected. The owner asked whether that self-check is enough to confirm the VSA, ABS, and airbag systems. The expert said the computer is thorough and that normal lamp behavior after startup is sufficient, while suggesting a dealer inspection if doubt remains. The owner agreed that the startup lamp check would have to be enough.
