2008 Honda Ridgeline Service announcement
6,400 MILES • 6 CYL • AWD • AUTOMATIC
THE ERN
I have changed the oil and filter. How do I get the message " service oil " to go off on Dash: Honda boys say can be done by pushing the right buttons on dash, but of course won't tell. Gotto lov it. Thanks
Aug 26, 2008 at 5:39 AM
HONDA TECH 1818
  • 536 POSTS
Resetting the Engine Oil Life Indicator
Turn the ignition switch ON (II).
Step 1: Press the SELECT button repeatedly until the oil life is displayed (if oil life is more than 15 %) or the maintenance message is displayed (if oil life is less than 15 %).
Step 2: Press the RESET button for about 10 seconds. You will see a service message to reset the maintenance item code(s) ''MAINT RESET.''
Step 3: Select the appropriate answer, ''MAINT RESET > N'' (NO) or ''MAINT RESET > Y'' (YES) by pressing the SELECT button repeatedly. ''>N'' or ''>Y'' is displayed on the outside temperature display.
Step 4:Select the ''MAINT RESET > Y'' (YES) and press the RESET button again to reset the engine oil life to ''100.''
Nov 21, 2009 at 6:39 PM
