2006 Honda Ridgeline AC
2006 HONDA RIDGELINE
HANSKAISER
Air Conditioning problem
2006 Honda Ridgeline 6 cyl Four Wheel Drive Automatic 71k miles
My AC appears to have stopped working although the controls on the dashboard indicate it is running. The fan simply doesn't blow out of the vents. Fuse problem? I don't know and the manual that came with the car isn't much help in determining which fuses might cause the problem.
I see someone else in this forum had a similar problem.
Aug 11, 2009 at 12:55 PM
HONDA TECH 1818
  • 536 POSTS
It could be the fuse here is guide that will help you.
Let us know what you find we are here to help.
Nov 15, 2009 at 6:56 AM
