replacing fuel pressure regulator in '98 Prelude
JARMEARS
  • 6 POSTS
Is there anything that I should be cautious of when replacing my fuel pressure regulator in my '98 Honda Prelude SH, or is it pretty straight forward? Should I be worried about fuel leaking everywhere in the process or anything like that. Any advice would be greatly appreciated. Thanks!
Aug 15, 2007 at 9:51 AM
MIKE H R
  • 3,094 POSTS
make sure there is no pressure in the line. if there is it will spray out with force. Keep anything electrical or open flames do it in a well ventilated area. remember it is not just the fuel that ignites but also the fumes.
Aug 15, 2007 at 10:01 AM
JARMEARS
  • 6 POSTS
What is the best way to make sure that there is no pressure in the lines?
Aug 15, 2007 at 10:29 AM
MIKE H R
  • 3,094 POSTS
first disconnect the battery , Loosen up the return line by the engine, let the pressure deop down before disconnecting the fuel line. There will be some fuel that comes out so have a catch pan handy.
Aug 15, 2007 at 10:34 AM
