Please help!!!!
1989 Honda Prelude Trunk Leak
Please help!!!!
Please help!!!![/quote:6f9685624f]
You must go water hunting. Get a friend that you trust, and have them lock you in the trunck (might be a good idea to have the back seat removed). Oh, and have a flash light. Your friend is to make it rain with a water hose. Dont shoot hard water directly on the seal, but spary the car as if it were raining. Look for the leak on the trunk seal. If it stays dry, then look at the back window seal. I have seen the rear window seal leak, and if you take it to a glass company, they can remove the glass, clean it, and reinstall with a new seal. Problem solved.
If its not the trunk or rear window, look at the sunroof and side windows. Sometimes water can get in a channel and run a long way before it shows its head.
Good luck and post the fix when you find it.
Suggested Repair
Have a helper spray the car lightly with a hose while you inspect from inside the trunk with a flashlight and the rear seat removed if needed. Check the trunk seal first, then the rear window seal; a glass shop can remove, clean, and reseal a leaking rear window. If those stay dry, inspect the sunroof and side windows, since water can travel through channels before appearing in the trunk or rear seat.
Conversation Summary
The owner of a 1989 Honda Prelude reports rainwater wetting the trunk and soaking the rear seat, the same issue they had on a 1985 Prelude. They doubt a sunroof leak because the sunroof itself does not appear to leak. The expert recommends a controlled water test, checking the trunk seal and rear window seal first, then the sunroof and side windows because water can travel through channels before showing up.
