1996 Honda Prelude Bent Valves
2 - Get a new/used engine that is the SAME are you have right now. It will save you from having to buy all the new/different stuff.
3 - Get a personal loan and get a VTEC. You'll need different motor mounts, new computer, new complete wiring harness, radiator hoses, slight exhaust modifacations, and a few other things that I'm sure I'm forgetting. But you will still pass the smog test, so that's a plus. :)
Suggested Repair
If the pistons and cylinder walls are undamaged, replace the cylinder head with a new or remanufactured head instead of swapping the engine. If an engine is replaced, use the same engine type to avoid extra parts. A VTEC conversion needs different mounts, a computer, wiring harness, hoses, and exhaust changes; verify California smog compliance before proceeding.
Conversation Summary
The owner of a 1996 Honda Prelude SI had a timing belt break and bend valves, and shops suggested replacing the 140,000-mile engine. Experts advised checking the pistons and cylinder walls and replacing only the head if they are sound, which should cost less. They also said a matching engine is simpler than a VTEC swap, which requires additional parts and should be checked against California emissions rules.
