idle drop
KB96747
i have an 89 prelude Si 2.0 was sitting for a while not shure how long from previous owner runs o.k but when it starts it almost dies the idles at around 750-850, when i push in the clutch it goes down under 500 or stalls. checked vac hoes, what could cause this problem ?
Feb 16, 2006 at 4:26 PM
FISHERMAN
  • 937 POSTS
tune-up the engine (spark plugs wires, fuel filter, air filter, rotor and distribuitor cap)
Feb 17, 2006 at 1:03 AM
KB96747
i have new NGK spark plugs, 9mm wires, MSD ignition system & performance intake. checked rotor and distribuitor cap both in good condition fuel fliter has not been replaced but fuel pressure is normal. it idles o.k its just when the clutch is pressed it drops. Could it be something in the trans?
Feb 19, 2006 at 4:05 PM
Discussion summary
idle drop
Driver of a 1989 Prelude Si 2.0 says the car sat for an unknown time; it runs but on start almost dies. Idle is about 750–850 rpm but drops below 500 rpm or stalls when the clutch is pressed. The poster checked vacuum hoses and reports new NGK plugs, 9 mm wires, an MSD ignition, performance intake, and that rotor and distributor cap look good; fuel pressure reads normal though the fuel filter hasn’t been replaced. The poster asks whether the transmission could be the cause.
Reported outcome: The poster did not report a fix or resolution.
Read the original discussion
