can't find idol
CCLOWVOLT
I have a 1990 honda prelude si with a 2.05L and when it is at idol it surges from 1500rpm to about 2500rpm I have replaced the throttle body, checked for vacuum leaks, and made sure the engine ground is good. HELP!
Nov 19, 2007 at 8:36 AM
BMRFIXIT
  • 19,053 POSTS
[quote:3bec38d202="cclowvolt"]I have a 1990 honda prelude si with a 2.05L and when it is at idol it surges from 1500rpm to about 2500rpm I have replaced the throttle body, checked for vacuum leaks, and made sure the engine ground is good. HELP![/quote:3bec38d202]
DID U CHECK THE COOLANT
Nov 19, 2007 at 9:23 AM
