1990 Honda Prelude Battery Light
KRIS79
Hello, I have a '90 Prelude SI. My battery light keeps coming on , then my windows, wipers , radio, and eventually the car itself, winds down then stops working. I just replaced the battery, as the cylinders were empty, I thought this was the problem.. I cleaned the posts, that seemed to work for a day, the new battery worked for a day, now Im having the same problem again. What would be making this happen, i know the alternator is an option, but could it be something else???
May 22, 2007 at 6:52 AM
BRUCE HUNT
  • 3,754 POSTS
It should still be the alternator. Even a test will show that it is charging and the rate of the charge could be correct or on the high end. The problem usually is that it does not know when to stop charging and overcharges the battery. This will basically boil out the liquid in the cells causing the battery to fail.
May 25, 2007 at 1:38 AM
Suggested Repair
Have the alternator tested and replaced if it overcharges. A charge-rate test can look normal or high while the regulator fails to stop charging, boiling the battery dry and causing the electrical system to fail.
Conversation Summary
The owner of a 1990 Honda Prelude SI reported a battery light followed by windows, wipers, radio, and the engine shutting down. A new battery and cleaned terminals helped only briefly. The expert said the alternator is still the likely cause because it can overcharge and boil the battery electrolyte even when a charging test looks acceptable.
