bad radiator
CHICOTHEMAN
i hav e a 1992 honda prelude si.it has a bad radiator, fins are rotted at bottom. it has 123,000 miles. i also have oil leak rear main seal. temperature gage never states its overheating. it stays at a normal reading. how much damage have i done to the engine and the transmission. it also leaks coolant from radiator,thanks
May 12, 2007 at 6:13 AM
MIKE H R
  • 3,094 POSTS
as long as the car does not overheat or run out of oil it should be ok, would get the radiator fixed and oil leak if you are loosing a lot of coolant and oil.
May 13, 2007 at 2:25 AM
