1996 Honda Prelude Alternator Belt Removal Fix
TEMP
I just looking for how to take my alternator belt off i juss cant reach it i need to know what a need to do to get to it. Its a 1996 Honda Prelude si 2.2L 140,00 miles
Jun 25, 2007 at 5:28 AM
BRUCE HUNT
  • 3,754 POSTS
Without looking at a manual on that vehicle, you should have to loosen the bolt that pivots the alternator and is located at the swivel that connects to the engine. You would also need to loosen the bolt on the tightening arm for the alternator. Two bolts to loosen and the alternator should rock back and forth making belt replacement pretty easy. Think you can take from there?
Jun 25, 2007 at 6:26 AM
Suggested Repair
Loosen the alternator pivot bolt at the engine swivel and the bolt on the tightening arm. With both bolts loose, rock the alternator to release tension and remove the belt.
Conversation Summary
The owner of a 1996 Honda Prelude Si 2.2L could not reach the alternator belt and asked how to remove it. The expert advised loosening the alternator pivot bolt and the tightening-arm bolt so the alternator can rock and the belt can be replaced.
