97 honda prelude type sh idle and check engine codes
RAYCLOWN
  • 11 POSTS
i have a 97 honda prelude sh with 95000 miles and i am having a couple of problems. first problem is when i start my car when cold my idle will jump up and down slowly until my car starts too warm up then it stops. then sometimes after driving for like 30 mins it will start it again. this doesn't happend all the time but part of the time. i have checked for vaccum leaks and found none. i have replaced the idle air control valve and that didn't fix it either. so what else could it be. i also have two check engine codes which are p0450 , p0453, which i think has something to do with the fuel. but i put a new gas cap on it and that didn't fix it. if anybody could be of some help just let me know of what i can do. thanks a bunch.[img:3ae4b63c1d]http://www.2carpros.com/forum/automotive_pictures/61946_071406_1432_1.jpg[/img:3ae4b63c1d]
Mar 2, 2007 at 3:15 AM
BRUCE HUNT
  • 3,754 POSTS
The level of the coolant is a big factor. Make sure there is no air in the cooling system by using the bleeder to purge the air from it.
Mar 2, 2007 at 3:48 AM
RAYCLOWN
  • 11 POSTS
i don't think there is air in the coolant because i had my dad bleed it a few weeks ago. im just not sure when you can tell the air is all out of the system. thanks for the help so far.
Mar 2, 2007 at 5:36 AM
