2001 Honda Prelude oil
70,000 MILES • 4 CYL • FWD • MANUAL
THIBS 87
sometimes when i come to a stop my oil light starts to blink, it stops if i turn off the car and start it again, oil levels are fine what gives?
Jun 17, 2008 at 6:23 AM
KHLOW2008
  • 41,812 POSTS
Hi thibs 87,
Following are possible causes.
1. The oil pressure switch is faulty or wire connection is loose.
2. Oil strainer in the il sump is clogged.
3. Oil viscousity is too thick.
4. Oil pump is weak.
If you had used oil treatment and seldom drive the car, clogging is the highest possibility.
Jun 21, 2008 at 7:02 PM
