2001 Honda Prelude No pressure in clutch
ERE2S
2001 Honda Prelude
I got into my car and when trying to start it the pedal went directly to the floor. Went to bleed clutch line and saw there was no fluid in the line. Added fluid and still nothing. I then replaced the master clutch and slave cylinder (both which were visualy busted and leaking fluid). There is some, but hardly any pressure in the line after I bled the line multiple times. The slave cylinder is not enganging cause I cannot shift it into any gears. Dont want to take it to a mechanic but am running out of ideas. I have inspected the line from master to slave and I can see no leaks. Why no pressure, did I miss a step after replacing the parts?!
Feb 21, 2010 at 11:13 AM
  • 75,988 POSTS
The clutch master cylinder could be leaking internally
Feb 21, 2010 at 11:17 AM
