2001 Honda Prelude leaking gasket
98,000 MILES • 4 CYL • FWD • MANUAL
NORTHDOG
I have a leaking head gasket I think, I burn 1 liter of oil for every oil change or 5000km. How can I fix the leak? Do I need to replace all my gaskets or just the head gasket? Is my engine being harmed if I just keep the oil level up? How soon do I need to do the repair?
May 22, 2008 at 3:04 AM
KHLOW2008
  • 41,812 POSTS
To lose 1 liter to leakage means the leak must be very bad.
If not then you might have valve seal and/or piston oil ring problem which will burn off the oil.
With enough oil, the engine would run ok, but if it is burning oil, the plug would foul up much faster than they should. Engine power would not be 100 %.
May 26, 2008 at 7:20 AM
