2001 Honda Prelude clutch
2001 HONDA PRELUDE
85,753 MILES • 4 CYL • 2WD • MANUAL
FABOLOUS438
My car sturggles to be put in gear and my clutch seams as if it wont engage untill i fully step on it i was woundering if it just needs clutch fluid and where would i find the container to put the fluid in.
Nov 18, 2008 at 7:56 PM
  • 31,937 POSTS
Hi there , the clutch is the small reservoir next to the larger brake master cylinder, there will be only one pipe coming from the cylinder, if it is low, you will have a leak, this will have to be repaired & the system bleed of air, if the fluid level is OK, your clutch will problem need replacing as there is no adjustments.
mark (mhpautos)
Nov 18, 2008 at 8:20 PM
