2000 Honda Prelude EGR
150,000 MILES • 4 CYL • FWD • MANUAL
JET4ANG
I replaced my EGR valve and still get error 401 after a few miles. The check engine light comes on mainly when I deccelerate. Could this be a faulty solenoid or vacume leak? The motor only has 10000 mi. on it.
Nov 4, 2010 at 5:23 AM
WRENCHTECH
  • 20,760 POSTS
That is a "low flow" code. That is usually caused by a plugged up EGR passage through the throttle body.
Nov 4, 2010 at 5:45 AM
JET4ANG
So what you're saying is that replacing the EGR was unecessary? It was full of carbon. Is there any way to clean that or are we talking another teardown? I just had the engine rebuilt over the summer.
Thank you for your reply BTW. I can't seem to get any answers from these parts of Minnesota.
Nov 6, 2010 at 1:17 PM
WRENCHTECH
  • 20,760 POSTS
Yes, the EGR valve was probably unnecessary. You have to locate the passage and dig all the carbon out of it. It may turn into a small passage at one point exiting into the throttle body. A coathanger usually works. You may have to remove part of the throttle body. I'm not real familiar with the exact location of that one.
Nov 6, 2010 at 1:26 PM
