2000 Honda Prelude cv axel
150,000 MILES • 4 CYL • 2WD • MANUAL
ROB_G86
the outer splines in my cv axel are stuck i've used pb blaster and a hammer and still no luck .... and ive used a punch on the center of the axel and still no luck.. need help!! as well as the tie rod end and lower ball joint boots are torn
Oct 24, 2010 at 2:39 AM
BILLYMAC
  • 2,204 POSTS
you need a puller for this stubborn axle you can use a three jaw puller . or go to parts store borrow their cv puller.
the torn boots on the b joint and tie rod can be replaced go to your help section at your parts store to find these
Oct 24, 2010 at 12:45 PM
ROB_G86
okay thanks for all the help! any thing that i need to watch out for using the axle puller? any dangers?
Oct 25, 2010 at 1:40 AM
BILLYMAC
  • 2,204 POSTS
no pretty safe just use caution not to damage spline on hub or axle if you are reusing the axle. which you are prob not
Oct 25, 2010 at 7:05 AM
