1999 Honda Prelude Thermostat
1999 HONDA PRELUDE
125,930 MILES • 4 CYL • FWD • AUTOMATIC
GEMINI85
My mechanic recently removed the failed thermostat from my car. He suggested i don't replace it. My car gets hot only when i'm at a red light, stop sign, or in traffic. Is this an issue in need of a new thermostat or is it normal? Lately the outside temperature in Texas is upper 90's in the afternoon, where my car heats up.
Jun 19, 2010 at 3:38 AM
KHLOW2008
  • 41,814 POSTS
Hi GEMINI85,
The thermostat is for getting the best optimal operating temperature of the engine and SHOULD NEVER be removed.
If it is bad, it should be replaced. Without the thermostat, the coolant are free flowing and that would result in inconsistent temperatures. When driving in heavy traffic, the radiator fan switch is delayed coming on as the radiator is being cooled fast and giving a false reading of the coolant temperature.
You would need to check if there are air trapped in system and if the cooling fans are operating correctly.
Jun 23, 2010 at 7:36 AM
FONY67
  • 6 POSTS
Did the removal of the thermostat work? please provide result
Sep 28, 2012 at 8:01 AM
