1999 Honda Prelude rough idle
126,000 MILES • 4 CYL • FWD • MANUAL
CHEECH6922
  • 7 POSTS
my honda prelude has check engine light on, got it checked and read egr pending and misfire in cylinder 3. It also idles rough almost like a misfire but smoothes out when warm. What could be the problem?
Feb 6, 2009 at 11:33 AM
F4I_GUY
  • 3,302 POSTS
Do you know excatly what the EGR code was? The EGR valve could be partially open and that could act as a vacuum leak and cause a rough idle, as it warms up and expands it could close up that small leak. I would recommend getting the EGR system checked out.
Your cylinder 3 misfire may be related, but most likely not. The first thing I would check is if you need a tune-up. It could be a faulty spark plug, wire, injector, etc.
Feb 16, 2009 at 6:09 AM
