1999 Honda Prelude oil
215,000 MILES • 4 CYL • FWD • AUTOMATIC
TWH1949
Seems oil is leaking directly onto exhaust manifold is this a replacement of the valve cover gasket, if so what is involved and is this expensive, I have noticed some oil usage since this appx 1 qt/mo
Thks
Thomas
Feb 25, 2010 at 5:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
hard to tell you where oil leak is at when can't see the vehicle but if it is valve cover and your doing it yourself then its relatively inexpensive, around $30 for valve cover gasket set.
Feb 25, 2010 at 5:53 AM
