1999 Honda Prelude obd fault codes and where do i start tro
140,000 MILES • 4 CYL • FWD • MANUAL
PEARLMONKEY16
I just recentlly went to get my car smoged for i could re register it. It puled up codes PO300, which is multiple misfires detected and PO301-305 which is misfire detected on cylinders 1 thru 4. Any ideas what might be wrong or where i should start looking. Cuz my check engine light stays on and flashing. I reset the computer and it came back on in like 15 min.
Nov 2, 2009 at 9:15 AM
KHLOW2008
  • 41,812 POSTS
Hi pearlmonkey16,
Misfire codes are usually caused by bad spark plugs or related ignition system coponents such as distributor cap, rotor, wires ignition coils. You should start from here.
Nov 2, 2009 at 2:33 PM
PEARLMONKEY16
thanks for the help i already went and read in my book where it said i should do that too. So i ll probably go and buy the stuff tomorrow. Anyways thanks.
Nov 2, 2009 at 4:34 PM
KHLOW2008
  • 41,812 POSTS
You are welcomed and glad to be of service.
Spark plugs might require replacement but other items should be checked before purchase to avoid unnecessary expenditure.
Nov 2, 2009 at 11:23 PM
