1999 Honda Prelude no pressure on clutch pedal
104,000 MILES • 4 CYL • FWD • MANUAL
CANNERAY
asi turned on my car today i notice that the clutch pedal had no pressure, as i pushed it down the pedal will not go back up. so i checked my fluid level and all the clutch fluid semed to be out but i didn't notice any leaks, i can turn the car on without using the pedal since it seems that it won't pop back up and when off my car will go through all the gears. what can i do?
Jan 8, 2008 at 1:53 PM
  • 31,937 POSTS
If the fluid is low, there will be a leak at the master cyl or the slave cylinder, look under the dash where the clutch pedal is, any fluid? if so replace master cyl. Peel back rubber boot on slave cylinder, any fluid? if so replace and re bleed system.
Mark (mhpautos)
Jan 8, 2008 at 1:56 PM
