1999 Honda Prelude egr valve
1999 HONDA PRELUDE
223,000 MILES • 4 CYL • FWD • MANUAL
GARYG369
replaced egr valve, after 70 miles engine light came on again, i took off line leaving valve and could blow through it, the old valve had lots of buildup
Jan 31, 2010 at 6:36 PM
KHLOW2008
  • 41,814 POSTS
Hi garyg369,
What was the trouble codes retrieved?
Did you clean the passage under the EGR valve?
Feb 1, 2010 at 1:06 PM
GARYG369
[quote:944f4d5330="KHLow2008"]Hi garyg369,
Did you clean the passage under the EGR valve?[/quote:944f4d5330]
hi, the code was 401, no i didn't clean passage under egr valve, is it hard? anything else? thanks a lot for the reply
Feb 1, 2010 at 4:50 PM
KHLOW2008
  • 41,814 POSTS
Remove the EGR valve, spray some carb cleaner into the passage under the EGR valve and let it soak for a while. Use a stiff wire or something suitable used to poke the passage to dislodge the carbon and use compressd air to clear them. Repeat a few times if necessary.
Reinstall EGR valve and retest.
Feb 2, 2010 at 6:13 AM
