Check engine light is on and the fault codes are for all cylinders misfiring. I have replaced Plugs2x, rotor, distributor cap, coil, ignition control module, and finally distributor. The car runs fine but the codes come back and the check engine light is still on-what else could it be?
Aug 6, 2008 at 10:36 AM
