1999 Honda Prelude blinker and low beam drivers side
110,000 MILES • 4 CYL • FWD • AUTOMATIC
CUJO83
blinkers do not work when lgihts are turned on. both high beam llights work. low beam works on passenger side and drivers side blinker light stays on
Nov 1, 2008 at 4:38 AM
KHLOW2008
  • 41,812 POSTS
Hi cujo83,
The issue should be a grounding fault. Check the groundings inside engine compartment at front fender behind the headlights and the rear taillights.
Nov 27, 2008 at 2:08 AM
