1998 Honda Prelude oxygen sensor
1998 HONDA PRELUDE
98,500 MILES • 4 CYL • FWD • AUTOMATIC
MANNY1998
got a check engine light and hooked up an obd scanner. result was a defective o2 sensor #1, which is b4 the cat. conv.. where can i find the o2 sensor #1 on my honda prelude 1998 ( standard ). i've looked on the manilfold but it's not there, is it further down the manilfold. do i have to bring it to a mechanic to fix this or can i do it by myself. thanks.
Feb 18, 2008 at 11:00 AM
2CARPRO JACK
  • 11,533 POSTS
If you can clear the code with your scanner it is a DIY project. The new one will screw in and plug in, just clear the code and you are on your way
Feb 18, 2008 at 11:18 AM
