1998 Honda Prelude left turn signal assembly replacement
1998 HONDA PRELUDE
145,500 MILES • 4 CYL • FWD • AUTOMATIC
CCCOOLIDGE
In replacing the signal assembly do I need special tools? Is it a do it yourself project? I am mechanically inclined.
Jan 21, 2009 at 10:08 AM
KHLOW2008
  • 41,814 POSTS
Hi cccoolidge,
You need torx bits to remove the airbag. Others are normal tools for removing the steering wheel and screwdriver.
Care has to be taken when handling airbags and if you are not trained for it, I would not recommend DIY.
Jan 24, 2009 at 2:30 AM
