1998 Honda Prelude ignition coil, crack in housing
134,000 MILES • 4 CYL • 2WD • MANUAL
DYAMIMT
These were the notes along with the suggestion of a new catalytic converter after diagnostic, full tune-up, and check engine light coming back on. Is the cat converter a crucial fix? What should I do about the ignition coil?
Jun 29, 2008 at 7:23 AM
KHLOW2008
  • 41,812 POSTS
Hi Dyamimt,
If the coil housing is cracked, it has the tendency to misfire under load so you should replace it.
Get tha coil replaced and see if the catalytic code disappears.
Jun 29, 2008 at 8:25 AM
DYAMIMT
Great thanks!
Jun 29, 2008 at 3:43 PM
