1998 Honda Prelude
SANNIESOJEWSI
1998 Honda Prelude
my car's check light has been on for over 5 motnhs now, the code reader is stating that there is an inssufficcient air flow throught the EGR valve, i have replace the valve and ran seafoam through the manifold and the light is still on, how can i fix this problem?
May 27, 2009 at 9:45 AM
  • 31,937 POSTS
Hi there,
Did you clear the code when you did the jog?
Mark (mhpautos)
May 27, 2009 at 5:49 PM
SANNIESOJEWSI
yes i have reset the code after i replace the valve and after the sea foam, the light came back on after both repair was done, and read the same code
May 28, 2009 at 9:28 AM
