1997 Honda Prelude Runing very lean
1997 HONDA PRELUDE
160,000 MILES • 4 CYL • FWD • MANUAL
GENE2012
My prelude is running very lean and i don't know what it could be any more. I have new O2 sensors, new map sensor, new cat, cleaned the egr and the intake manifold, new spark plugs, new park plug wires and did a compression test and they all good. I have a A/F gauge and it running almost all the way lean. When I drive it it struggles a little bit and the muffler makes a poping noise. I did the timing twice cause I was afraid it was off but it's good. I checked it with a timing light. I have no more idea what it is. The car start fine and everything is good but it's just way to lean to drive.
Jul 3, 2010 at 11:48 AM
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Jul 3, 2010 at 12:48 PM
GENE2012
I checked all of the listed and that's why I'm stumped. The only thing i can think of now is taking it to the shop. Anymore ideas why it's running so lean?
Jul 3, 2010 at 1:41 PM
