1997 Honda Prelude Crank sensor
TRAVILLIAN_ RACING
Engine Performance problem
1997 Honda Prelude 4 cyl Front Wheel Drive Manual
My car will not start were is the crank sensor fuse located and were is the crank sensor located
Jan 18, 2010 at 8:19 AM
KHLOW2008
  • 41,812 POSTS
Hi Travillian_ racing,
The CKP and TDC are located at lower left side of engine, near timing belt area.
Why do you think it is the crank sensor that is at fault?
Have you checked other items?
https://www.2carpros.com/kpages/first_things.htm
If you need to know how to go about, check the above links for the procedures.
Jan 18, 2010 at 9:26 AM
TRAVILLIAN_ RACING
It will crank it's guts out run down the battery and still can't get a spark out of any of my plug wires I'm out of ideas
www.travillianracing.zoomshare.com
Jan 18, 2010 at 10:44 AM
KHLOW2008
  • 41,812 POSTS
Have you tested the ignition coil, ignition control module and power supply to the ICM?
Jan 18, 2010 at 11:31 PM
TRAVILLIAN_ RACING
I have tested the coil it's good where Is the power supply located?
Jan 19, 2010 at 8:47 AM
KHLOW2008
  • 41,812 POSTS
Power supply to the ICM is via the ignition switch.
Check the Black/Yellow wire for voltage with ignition switch turned ON and while cranking.
Jan 19, 2010 at 11:33 PM
