1997 Honda Prelude color coded rod bearings
1997 HONDA PRELUDE
107,000 MILES • 4 CYL • FWD • MANUAL
GINO64
I have a stock crankshaft and aftermarket pistons and rods. The stock rods all have different color codes.The aftermarket rods say use all green code bearings. Is this correct.
Jul 25, 2008 at 3:29 AM
KHLOW2008
  • 41,814 POSTS
Hi gino64,
If you want to get the most accurate color codes, you need to use plastigage to measure the clearance to determine if it is correct.
Since it is after market conrods, ( what was wrong with the original rods), it most probably won't be as accurate. Marks are punched on the crankshaft and conrods their combination determines the color codes of the bearings.
Aug 3, 2008 at 4:35 AM
