1996 Honda Prelude Idles rough
1996 HONDA PRELUDE
121,000 MILES • 4 CYL • 2WD • AUTOMATIC
WMSSERVICES
My 96 prelude timiing belt broke, causing bent valves. A mechanic removed the head and had a valve job done on it. He changed the timing belt, water pump,plugs,wires,distributor cap,rotor and put it back together, but it ildes rough and is missing; plus it will not stay runing.
Oct 4, 2008 at 3:50 AM
KHLOW2008
  • 41,814 POSTS
Hi wmsservices,
You need to
1. Recheck the timing belt synchronisation.
2. Check valve clearance.
3. Check ignition timing.
4. Idling speed.
Oct 11, 2008 at 6:05 PM
