1996 Honda Prelude clutch
KEITH DONNELLYL
Transmission problem
1996 Honda Prelude 4 cyl Two Wheel Drive Manual
my clutch seems to have failed.pedal has lost all pressure it happened over night without warning
Jan 11, 2010 at 12:58 AM
KHLOW2008
  • 41,812 POSTS
Hi keith donnellyl,
Check the clutch reservoir fluid level.
The hydraulic system has failed and it should be due to a leakage either at the master cyliinder, slave cylinder or the hydraulic lines.
If it is a minor leak, topping up the fluid and bleeding the the system can get you some mileage to get the vehicle to the nearest place for repairs.
Jan 11, 2010 at 3:53 AM
