1996 Honda Prelude 1996 honda prelude
1996 HONDA PRELUDE
140,000 MILES • 4 CYL • 2WD • MANUAL
CDMORALES009
i put the clutch in and turn the key my car starts to go crazy! the front lights , rear lights, and gauges lights start to blink off and on. the blinker blinker blinker blinker noise inside the car goes on and the car doesnt start!. the lights keep blinking when i take the key out and close the doors. i took a screwdriver and by pass the starter and the car starts right up. but the lights keep blinking but goes off after a couple of minutes. its not the battery. help help!!!!!
Sep 29, 2008 at 12:52 PM
BMRFIXIT
  • 19,053 POSTS
Its the ALARM system
take the key place it in the door lock and cycle lock and the unlock
and try to start
if that did not work do this
disconnect the battery place key in the ignition and turn it ON
reconnect the battery
and then it should start for you good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sep 29, 2008 at 2:36 PM
CDMORALES009
wow thanks guys!! you really are pros! Have a great Day.
Sep 30, 2008 at 2:08 PM
