1995 Honda Prelude smog test
1995 HONDA PRELUDE
238,000 MILES • 4 CYL • 2WD • MANUAL
NAVYUCXLA
Before I spend 75 bucks for an assessment and then maybe 300 bucks for a repair that may or may not work, can you tell me what could be the cause why I failed my smog test. I recently bought a 95 Honda Prelude VTEC and the previous owner said he changed out the Catalytic Converter and O2 sensor in April, yet the results show a Gross Polluter and the NO reading was 1952 (max can be 704). It also has a cold air system. Help please...
Sep 8, 2008 at 1:29 PM
KHLOW2008
  • 41,814 POSTS
Hi NAVYUCXLA,
High Nox reading is consistent with a catalytic converter failure.
Is there any other issues such as Check Engine Lamp showing or performance related.
Was the replaced cat converter and O2 sensor OEM or aftermarket?
Oct 3, 2008 at 2:02 PM
