1995 Honda Prelude power window on driver's side inoperativ
121,000 MILES • 4 CYL • 2WD • MANUAL
DINO
passenger side works fine
Oct 27, 2008 at 12:01 PM
  • 31,937 POSTS
Hi there,
You will need to remove the door trim and check the power supply to the motor, if the supply is OK the motor will be faulty, if no power check that the switch is functioning correctly, if you don't feel up to doing this your mechanic can check this in about 1/2 Hr.
Mark (mhpautos)
Oct 27, 2008 at 1:31 PM
DINO
I have a voltage meter, but not familiar with the operations. What settings should I use. Thanks
Oct 28, 2008 at 3:25 AM
  • 31,937 POSTS
Hi there,
Use 12Volts, now if the plug into the motor has only 2 wires, they will switch polarity for up and down, so don't get confused on that.
Mark (mhpautos)
Oct 28, 2008 at 8:59 AM
