1995 Honda Prelude fog light
150,000 MILES • 4 CYL • 2WD • MANUAL
95VANG
yes i was wondering if the two stock front fog light suppose to be on or off when the light switch is on?
also there is this wire that is lead with the same wire it dont have any other wire that is connected to it down on the front fog light?
Nov 28, 2009 at 4:13 PM
KHLOW2008
  • 41,812 POSTS
Hi 95vang,
The fog lights are operated with an independent fog light switch and can only be turned on when the headlights are turned ON. Power is via the left headlight fuse for the fog light relay.
I am sorry I do not understand the second part about the wire lead, can you please explain?
Dec 5, 2009 at 4:40 AM
