1995 Honda Prelude clutch pedal soft
190,000 MILES • 6 CYL • FWD • MANUAL
LUCKYSTARS4583
i have a 95 honda prelude w/ 190000+ miles it runs well and is in good condition other than a problem that has stated to occur with my clutch. when i push it in to start the car i have to bury it in the floor.there is absolutely no pressure in the line. however if i let the car run and pump it 10 or so times i get 80% recovered. also after i drive for awhile it seems fine. the resevior is almost full and when i pump it there is no leaking fluid. can you help me? thanks!!
Oct 30, 2008 at 12:28 PM
  • 31,937 POSTS
Hi there,
I feel that this is air in the system, bleed and re check for a small leak, peel back the rubber boot on the slave and check up under the dash at the rear of the master where it come through the fire wall, start here.
mark (mhpautos)
Oct 30, 2008 at 1:20 PM
