1994 Honda Prelude sunroof removal
JAYMOULTIMO
Interior problem
1994 Honda Prelude 4 cyl Front Wheel Drive Automatic
i want to replace the metal sunroof honda prelude 1994 wit sheet metal ive already cut the sheet metal i just need to know how to take sunroof apart
Sep 13, 2009 at 4:00 AM
KHLOW2008
  • 41,812 POSTS
Hi jaymoultimo, Our database does not have a good description nor pictures of the sun roof removal procedures. Hope the following is sufficient. Removal & Installation Remove front roof trim. Align position "A" of frame to mounting screw.
https://images.2carpros.com/forum/automotive_pictures/192750_SunRoof94PreludeFig05_2.jpg
Remove mounting screws and clips. Slide sun roof slightly forward. Taking care not scratch sun roof liner, slide from under sun roof and remove it. Remove mounting screws from panel brackets on both sides. Lift up and remove sun roof panel. To install, reverse removal procedure.
Sep 16, 2009 at 7:28 AM
