1994 Honda Prelude loosing braking ability
154,000 MILES • 4 CYL • FWD • MANUAL
CORYCOR
The car looses its braking ability at times i just replaced the all the pads checked for leaks and filled it with brake fluid. As im driving and the car starts heating up it will sometimes not brake almost at all.
May 9, 2009 at 2:43 PM
TED-E-DEE
  • 109 POSTS
Does brake pedal fade to floor, or does it feel like it's hardening up ? If it fades to floor, you may have a master cylender problem. A bad master cylender can cause pedal to go to floor without leaking fluid. If it hardens up, you may have a problem w/vacuum to booster or a bad booster.
May 12, 2009 at 5:56 AM
