1993 Honda Prelude tail lights/parking lights out
165,000 MILES • 4 CYL • 2WD • MANUAL
BRODLAND
My honda prelude's tail lights and parking lights stopped working suddenly. The head lights, brake lights, reverse lights, turn signals, and four way flashers all work fine. its just the tail lights and parking lights that dont work. They have come on a few times since they went out, but they just go out again after a few minutes, and all the fuses are good. that's why im thinking its a relay, but i cant find a relay for the tail/parking lights. Its not labeled on either of the fuse boxes.
Anyone know if there is a tail/parking lights relay, and where i can find it on a 93 prelude? ...and maybe what it looks like?
Feb 13, 2009 at 5:23 PM
MERLIN2021
  • 17,250 POSTS
It would seem more like a bad connection, remove the bulbs and look for any sign of corrosuion, (greenish) goo in the sockets and connectors. You also need to inspect the ground wires...
https://images.2carpros.com/forum/automotive_pictures/62217_Hondaa_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Hondab_2.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Hondac_1.jpg
Feb 13, 2009 at 8:39 PM
BRODLAND
but all eight of the parking/tail lights have gone out. Would that happen if it there was corrosion in just one of the bulb sockets? Also, this happened right after I smelled a strong electrical buring smell in the car.
Just out of curiousity, is there a relay for these lights? and if so, where can I find it?
Feb 14, 2009 at 4:02 AM
MERLIN2021
  • 17,250 POSTS
There is an integrated control unit next to the fuse box, but if the tail and parking lights are out, suspect a wiring problem...
https://images.2carpros.com/forum/automotive_pictures/62217_hona_1.jpg
I am having trouble uploading pictures right now, I will try again later. But the control unit does the flashers, oil pressure warning and other stuff, if these work I think it's wire or fuse related.
Feb 14, 2009 at 4:45 AM
BRODLAND
Ok, so just to reiterate, there is no relay for the tail/parking lights, right?
Although i've checked all my fuses, and they're all good, I can't seem to even find a fuse for the tail/parking lights!
And if it is wiring, where would the problem be if the side, tail, and corner parking lights are all out?
Thanks.
Feb 15, 2009 at 6:35 AM
MERLIN2021
  • 17,250 POSTS
FUSE PANEL LOCATION Fuse box is located under dashboard on driver's side. Underhood relay panel is located on right side of engine compartment next to battery. A list of protected circuits and fuse ratings for each is found on a chart inside fuse box and on fuse panel cover. UNDERDASH FUSE PANEL IDENTIFICATION (1992-95) Fig. 1: Underdash Fuse Panel Identification (1992-95) Courtesy of AMERICAN HONDA MOTOR CO., INC.  1 - Not Used  2 - 7.5 Amp PGM-FI ECM, PGM-FI Main Relay, Starter Signal, Sub Gauge (Brake Check Circuit)  3 - 15 Amp Front Foglights (Option)  4 - 10 Amp PGM-FI Main Relay  5 - Not Used  6 - 15 Amp Seat Heater System (Canada)  7 - 30 Amp Sun Roof Open Relay, Sun Roof Close Relay  8 - 10 Amp Daytime Running Lights Control Unit (Canada)  9 - 15 Amp Heater Control Panel, Power Mirror System, ABS Control Unit, 4WS Control Unit, Fan Timer Unit, Mode/Recirc. Control Motor Heated Mirrors (Canada)  10 - Not Used  11 - 10 Amp Seat Heater Main Relay (Canada), A/C Compressor Clutch Relay, PGM-FI, ECU, Rear Window Defogger Relay  12 - 7.5 Amp Daytime Running Lights (Canada)  13 - 10 Amp Gauge Lights, Indicator Lights, Clock, Back-Up Lights  14 - 7.5 Amp Cruise Control System  15 - 20 Amp Driver's Power Window System  16 - 20 Amp Passenger's Power Window System  17 - 30 Amp Windshield Wiper System  18 - 10 Amp Stereo Radio/Cassette Player, Cigarette Lighter  19 - 15 Amp (Without SRS) (1992), Not Used (1993-94) PGM-FI Main Relay, A/T Control Unit, Fan Timer Unit, ELD Unit NOTE: Replacing a fuse with one of a greater rating greatly increases chances of damaging electrical system. If replacement fuse with proper rating for circuit is not available, install one with a lesser rating.  20 - Not Used  21 - Not Used  22 - 10 Amp 4WS Control Unit, 4WS Front & Rear Steering Angle Sensors  23 - 15 Amp SRS Unit, Transmission Control Module (TCM), PGM-FI, Radiator Fan Control Module, Vehicle Speed Sensor (VSS), Charging System  24 - 10 Amp SRS Unit UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION (1992-94) Fig. 2: Underhood Fuse & Relay Panel Identification (1992-94) Courtesy of AMERICAN HONDA MOTOR CO., INC.  31 - 50 Amp ABS Motor Relay  32 - 100 Amp Power Distribution  33 - 50 Amp Ignition Switch (BAT)  34 - 40 Amp Rear Window Defogger Relay  35 - 40 Amp Blower Motor Relay  36 - 40 Amp Seat Heaters (Canada), PGM-FI Main Relay, Fog Lights (1994)  37 - 40 Amp Sun Roof System, Power Window System, Daytime Running Lights Control Unit (Canada)  38 - 60 Amp 4WS Control Unit  39 - 15 Amp Turn Signal/Hazard Relay, Hazard Lights  40 - 15 Amp ABS Control Unit (B2)  41 - 15 Amp Horns, Horn Relay (With SRS), Brakelights, Brakelight Signal  42 - 20 Amp Parking Lights, Dash Lights  43 - 10 Amp Clock, Stereo Sound System, 4WS Control Unit, Power Antenna ECM, A/T Control Unit (TCM), PGM-FI (1994)  44 - 15 Amp Power Door Lock Control Unit  45 - 15 Amp Condenser Fan Motor, Fan Timer Unit  46 - 15 Amp Ceiling Light, Cigarette Lighter Relay, Trunk Light, Ignition Key Light, Interlock System  47 - 15 Amp Radiator Fan Motor  48 - 7.5 Amp ABS Control Unit  49 - 20 Amp ABS Control Unit (B1)  50 - 20 Amp Right Headlight  51 - 20 Amp Left Headlight, High Beam Indicator Light, Fog Light Relay (1994) WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
https://images.2carpros.com/forum/automotive_pictures/62217_prea_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_preb_1.jpg
Feb 16, 2009 at 8:04 PM
SHINOBIKANEKO
Brodland, I know exactly where you are at. I could list everything on your car that doesn't work due to your situation.
Step 1:LOCATE/TEST/REPLACE IF NECESSARY with a 20AMP fuse, FACTORY LOCATION FUSE NO. 42
(this fuse is located under the hood, toward the back of the ENGINE BAY [passenger side and to the back left side of the engine compartment], inside a black fuse box with a easily removable cover)
can also be located in the pictures/schematics posted by a previous responder
-I found that mine was fine-
Step 2:
Test/replace COMBINATION LIGHT SWITCH
(that is the repair denotation of the entire turn signal switch)
***IF YOU GET TO THIS PONT***
If you get to this point and have not found a resolution, then you and I have the same problem.
You have a SHORTED (connection to another signal-ground or hot-) or an OPEN (break in this connection) SIGNAL/CONNECTION)
You and I are going to be looking for an abnormality in the wiring/connection plugs
Our signal runs from the NO. 42 FUSE to the COMBINATION LIGHT SWITCH > to a junction where our signal is split into an additional signal
From this junction, one signal runs to one tail light, and the other singnal runs to other multiple locations
If our problem gave us one tail light working while the rest of our original symptOms remained, the we would be looking for our OPEN between this junction and the problematic tail light and the rest of our components which have malfunctioned
HOWEVER, we are looking for, either an OPEN signal between our COMBINATION LIGHT SWITCH and the junction where our signal splits first, or a SHORT between our COMBINATION LIGHT SWITCH and and any of our seemingly malfuntioning components. Also, these components must have the signal introduced to it directly.
-this is where I am at currently investigating the same issue-
Good luck!
Oct 17, 2012 at 4:47 AM
COTYMARSHALL
I had this problem. Still kind of do. Read this post and it helped me through my search. My problem was a loose wire in the plug where the harness hits the under dash fuse box. Tension on this harness over time loosened the wire in the plug. I need to get a new plug from the junkyard( well used) until I find one I just put tension the opposite direction and wrapped it with electrical tape. If it flickers out I just push in on the plug..... Hope this helps anyone who comes across this.
C501 dashboard harness
Feb 13, 2013 at 6:14 PM
