1993 Honda Prelude service transmission
136,598 MILES • 4 CYL • 2WD • MANUAL
JCM0410
I would like to check my tranny oil i know you take a plug out of the side to check but i have 2 plugs and im not sure which one i have to take out. Also i need to know how i would change it if needed Thank you
Jul 24, 2008 at 2:24 AM
KHLOW2008
  • 41,812 POSTS
Hi jcm0410,
To check the trans oil level, you need to remove the plug on the transaxle housing, just behind the CV joints. Filling is via this plug hole till lower level.
Lower plug with square key is for draining.
Aug 3, 2008 at 4:07 AM
